pauldoherty Posted December 30, 2005 Share Posted December 30, 2005 Hi all; Im finalising this visual today and would appreciate any comments and indeed crits on it. Thanks in advance Link to comment Share on other sites More sharing options...
Msamir Posted December 30, 2005 Share Posted December 30, 2005 I think its nice but the reflection on all the glass is wierd. Link to comment Share on other sites More sharing options...
pauldoherty Posted December 30, 2005 Author Share Posted December 30, 2005 I agree, I might play with it in photoshop. Do you think the glass could be darker in the whihe areas Link to comment Share on other sites More sharing options...
DAN212222 Posted December 30, 2005 Share Posted December 30, 2005 yes it looks a bit bright as already said try playing with it in photoshop, you may also want to post it in the wip or finished work section, good luck dan Link to comment Share on other sites More sharing options...
Iain Denby Posted December 30, 2005 Share Posted December 30, 2005 Paul I don't think the original photo was good enough to use. Also, you manipulation of the steep road looka little odd too. The model lacks a bit of detail, such as flashings around the dorma windows and ridge tile on the roof. Link to comment Share on other sites More sharing options...
SunGlare Posted December 30, 2005 Share Posted December 30, 2005 I'm not sure if the color of the stonework is correct... it's too yellow. But it might be architects' decision, and then You're covered. What is seem to be wrong with the uphill stret is the asphalt texture. I think You did that with the PSP. You can not ignore nature of particular texture, the asphalt for example is all about oil spots in the middle, and lighter bands toward the edges. You know... just rotate it, to align the street. What You have is the pependicular to the direction. Yeah.. the window refl is too intense. maybe some post proces corr. Try to clean up the existing brick short wall. Because Yours look too clean and shiny, maybe incresing the bump? Model looks time comsumig, so maybe add feww more hour and set up some radiosity. Shadows doesnt match. Yours and photo. Link to comment Share on other sites More sharing options...
r_mc_gowan Posted December 30, 2005 Share Posted December 30, 2005 the shadows stand out alot, like there are two light sources in the image. is this particular road in co.derry? im sure i know it! check out ur private messages paul Link to comment Share on other sites More sharing options...
