Jonathan Sanchez Posted January 2, 2006 Share Posted January 2, 2006 Hey guys, I've posted this same room under daylight last week at http://www.cgarchitect.com/vb/showthread.php?t=14034. Now I am rendering the same room but at night. Here's what I have so far. I dont really like it. I cant put my hand on what it is but something is not right. What do you guys recommend I do to make it more realistic? I'm using 3ds 8 and vray. I placed to vray lights on recessed ceiling lights and a spotlight for back lamp. See through lamp at front of pic I'm still working on so forgive if not of high quality. Link to comment Share on other sites More sharing options...
Ismael Posted January 2, 2006 Share Posted January 2, 2006 How about some IES Luminaires from Erco for the downlights? Maybe try that with Radiosity too for comparizon. Seems like there is too much even light in the space and lack of contrast. http://www.erco.com/download/en/en_index_download.htm The lighting analysis tool in Viz/Max is one of my favorite tools. Once somebody gave a simple IES distribution that made a nice pattern on the wall, however the intensity of it was around 8,000 fc which means that it was as bright as the Sun... Too much light and one is blinded and the same is true if there is no light. How much light would be needed depends on the task... http://www.ibacos.com/hpl4.html Ismael Link to comment Share on other sites More sharing options...
Yaseck Posted January 3, 2006 Share Posted January 3, 2006 I'm not any master in VRay, but I think the vray-lights are not good for the evening scene. You need highcontrast lights. Link to comment Share on other sites More sharing options...
Jonathan Sanchez Posted January 3, 2006 Author Share Posted January 3, 2006 Okay, I realized you guys were right. I have seen night shots with vray lights that were stupendous before, but I figured I'll give ies a shot. So I did and I've attached the result. I used quick setting because I was doing lots of tweaking so there is some noise I'll fix that w/final render. What do you guys think now? Link to comment Share on other sites More sharing options...
Ismael Posted January 3, 2006 Share Posted January 3, 2006 Nice improvement! Starting to look the part! Ismael Link to comment Share on other sites More sharing options...
Jonathan Sanchez Posted January 3, 2006 Author Share Posted January 3, 2006 Thanks for your advice Ismael. Really helped. Link to comment Share on other sites More sharing options...
Jonathan Sanchez Posted January 3, 2006 Author Share Posted January 3, 2006 Okay, Here's what I got so far. What do you guys think? Link to comment Share on other sites More sharing options...
Tim Saunders Posted January 3, 2006 Share Posted January 3, 2006 lots better. for the quality of the image, try throwing in a night city or neighborhood outside the window. thought it might not be there in reality, it would make it look a lot more convincing. Link to comment Share on other sites More sharing options...
Yaseck Posted January 4, 2006 Share Posted January 4, 2006 Look at the lamp at the corner. Does it really emit such soft light? I think the shape of the light on the walls should be more sharp. Link to comment Share on other sites More sharing options...
sya Posted January 4, 2006 Share Posted January 4, 2006 hai..im sya from malaysia..just want to know..what kind of lighting that u using for this scenes...and what type of color as usual u using for wall..actually i want to know a good matching for wall and lighting..tq Link to comment Share on other sites More sharing options...
Jonathan Sanchez Posted January 4, 2006 Author Share Posted January 4, 2006 Damn you Yaseck... You are right!!! :-) After I did some post rendering work I gotta rerender! I'm just playing thanks for advice u r right about that light. hey Sya, I dont throughly understand your question, but I am using ies lights with 3ds's Web files for recessed lights, and rendering w/vray irradiance map and light map. About the color of the wall it is: R-224, G-180, B-122. Link to comment Share on other sites More sharing options...
