parkdark Posted January 4, 2006 Share Posted January 4, 2006 how can i export a archicad file to cinema 4d Link to comment Share on other sites More sharing options...
pauldoherty Posted January 4, 2006 Share Posted January 4, 2006 You need to get yourself a copy of the cinema archicad exchange disc. Available at http://www.maxon.net Link to comment Share on other sites More sharing options...
Ace_Face Posted January 5, 2006 Share Posted January 5, 2006 You need to get yourself a copy of the cinema archicad exchange disc. Available at http://www.maxon.net You can use 3ds export from ArchiCAD. Open the 3D window Save As... select 3DStudio File from the drop down menu. The conversion is 3.28 to convert english to metric units (if that's necessary for you) as C4D uses metric for it's units. Link to comment Share on other sites More sharing options...
tomwaltz Posted January 6, 2006 Share Posted January 6, 2006 You have two options: 1) use 3DS 2) Get the C4D "Exchange" add-on from Maxon, which allows you to semi-link your Archicad model into C4D, allowing for much more interative editing. I think it's $100 USD. Link to comment Share on other sites More sharing options...
