Devin Johnston Posted January 4, 2006 Share Posted January 4, 2006 My company just purchased 7 new AMD Athlon Dual Core 64 bit 4400+ machines and I've been doing some comparison tests against an Intel 3.6 GHz Pentium. So far the AMD is 37% slower than the Intel, but I'm not sure if everything is working right. I have a dual processor dual core AMD Opteron system and the task manager shows 4 processors, these Athlon systems only show one processor in the task manager, but I think they should be showing two. Can anyone help me here, I don't know if these processors are functioning correctly. Link to comment Share on other sites More sharing options...
AJLynn Posted January 4, 2006 Share Posted January 4, 2006 It should show two processors. Sounds like your vendor screwed up - this should work without modifications, but did you check the bios and check with your vendor and MB manufacturer to see if there are any bios upgrades you need for the dual? Link to comment Share on other sites More sharing options...
Devin Johnston Posted January 4, 2006 Author Share Posted January 4, 2006 I'll check....I thought something was screwy. Link to comment Share on other sites More sharing options...
mtutaj Posted January 4, 2006 Share Posted January 4, 2006 what motherboard, did you get, the last system I installed, I had to update the bios and now it shows 2 cpu's. some of the motherboard manufacturers, now are able to let you update the bios thru windows now which is really nice, then all you do is reboot and your good to go. Mike Link to comment Share on other sites More sharing options...
Devin Johnston Posted January 4, 2006 Author Share Posted January 4, 2006 It turns out it was a BIOS problem, the boards shipped with a 2.xx version and when we updated they were at 19.xx, so I guess they've been sitting in a warehouse for quite some time. Link to comment Share on other sites More sharing options...
AJLynn Posted January 4, 2006 Share Posted January 4, 2006 Cool. Now can you show us some examples of what you can do with 7 dualcores? Link to comment Share on other sites More sharing options...
Devin Johnston Posted January 4, 2006 Author Share Posted January 4, 2006 Yes Sir! Link to comment Share on other sites More sharing options...
CVC Posted January 6, 2006 Share Posted January 6, 2006 go go go Maxer , can u show some cpu test ???? what's ur mainboard ??? Link to comment Share on other sites More sharing options...
DennisB Posted January 7, 2006 Share Posted January 7, 2006 It turns out it was a BIOS problem, the boards shipped with a 2.xx version and when we updated they were at 19.xx, so I guess they've been sitting in a warehouse for quite some time. Now what kind of performance are you getting relative to Intel? Link to comment Share on other sites More sharing options...
Devin Johnston Posted January 7, 2006 Author Share Posted January 7, 2006 The AMD system is a little more than 40% faster than the Intel 3.6 GHz 64 bit system. The AMD system is also $300 less than the Intel system, so as of right now unless Intel changes something either in their pricing or speed of their chips we will be buying all AMD systems. Link to comment Share on other sites More sharing options...
CVC Posted January 9, 2006 Share Posted January 9, 2006 @Maxer : this is my X2 4400+ with cinebench 03 , can u show yours ? Link to comment Share on other sites More sharing options...
Devin Johnston Posted January 9, 2006 Author Share Posted January 9, 2006 Sorry I don't have direct access to these machines, there only on my farm so all I can do is render benchmarking scenes and compare times. Should give the same results as cinebench though. Link to comment Share on other sites More sharing options...
jonel Posted January 9, 2006 Share Posted January 9, 2006 @Maxer : this is my X2 4400+ with cinebench 03 , can u show yours ? something is wrong with your setup, multiple CPU test should be almost 2x faster, ~ like this Link to comment Share on other sites More sharing options...
CVC Posted January 17, 2006 Share Posted January 17, 2006 something is wrong with your setup, multiple CPU test should be almost 2x faster, ~ like this sorry , i'm got a wrong result , that's my P4 3G , this is correct result on my X2 4400+ Link to comment Share on other sites More sharing options...
jonel Posted January 17, 2006 Share Posted January 17, 2006 4400+ overclocked at ~2,7GHz? or 64bit cinebench Link to comment Share on other sites More sharing options...
CVC Posted January 23, 2006 Share Posted January 23, 2006 4400+ @ 2.75ghz (275x10) cinebench2003 ( 32bit) Link to comment Share on other sites More sharing options...
marvins_dad Posted January 23, 2006 Share Posted January 23, 2006 Maxer - Who is building your machines? What brand? I'm currently looking at the Boxx machines, but wouldn't mind shopping around...and seeing as how you are in Houston, I thought I might give your vendor a look at. Link to comment Share on other sites More sharing options...
Devin Johnston Posted January 23, 2006 Author Share Posted January 23, 2006 We are currently buying XI computers and I’ve been very happy over the past 3 years with them. I also looked at Boxx and have purchased several render boxes from them for my rendering farm. To be honest I've found that the Boxx prices are much higher than other comparably equipped systems, your paying for the name. This is why we went with XI, I could get the same system for about $500 less than what Boxx was willing to sell it for. Link to comment Share on other sites More sharing options...
marvins_dad Posted January 23, 2006 Share Posted January 23, 2006 Thanks for the tip! (runs off to Xi website) Link to comment Share on other sites More sharing options...
