parkdark Posted January 4, 2006 Share Posted January 4, 2006 I have a problem. When i import a ArchiCAD file to 3D studio max my object is too small. How can i get a bigger one. Link to comment Share on other sites More sharing options...
Bugga_Guy Posted January 4, 2006 Share Posted January 4, 2006 I am not to familiar with archicad - are you importing as a dwg file? If you are make sure you use the rescale dialog box and make sure the incomming file units are the same Link to comment Share on other sites More sharing options...
parkdark Posted January 4, 2006 Author Share Posted January 4, 2006 no i export the file from archiCAD to 3d studio max like a 3ds. file Link to comment Share on other sites More sharing options...
skippy Posted January 4, 2006 Share Posted January 4, 2006 i prefer always dwg export from archicad like this u get archicad layers etc so its mutch more better to start working in max like this.... and abou scale problem.... check units also archicad export settings.... Link to comment Share on other sites More sharing options...
njoco2 Posted January 4, 2006 Share Posted January 4, 2006 I always export my drawings as .dwg`s (from ArchiCAD) , and I never had any problems importing them in MAX. You should check the scale and units of your drawing in ArchiCAD. pozdrav Link to comment Share on other sites More sharing options...
parkdark Posted January 4, 2006 Author Share Posted January 4, 2006 thank you about the advices. i will try it Link to comment Share on other sites More sharing options...
parkdark Posted January 4, 2006 Author Share Posted January 4, 2006 i have try with dwg. but the object is not 3d just the floor plan Link to comment Share on other sites More sharing options...
njoco2 Posted January 5, 2006 Share Posted January 5, 2006 First you have to open the 3d window in ArchiCAD and then save the model as .dwg. Link to comment Share on other sites More sharing options...
parkdark Posted January 5, 2006 Author Share Posted January 5, 2006 Hey thank you about that but now i have another problem. Can you tell me how to fix this. I cant see the full object Link to comment Share on other sites More sharing options...
