make a form, meld into main form
mtutaj
I have no idea if I am even using the right terms. I have a base sculpture that I need to meld this new object onto it.. I know someone had posted a plugin to do this, ive searched a little bit, but hopefully someone can really help me out, tring to finish this before morning. for the grayscale renders.
Here is the file, I am tring to wrap this stack around the main form.
http://www.perplexedmedia.com/form/test1.zip
Thanks to all
MIke (stressing a bit right now)
sorry but your file does'nt open for me..since I'm using max6. Anyways I think I understood what you need. You can use the Scatter option from the compound objects. You will be able to scatter the small meshes over a bigger mesh...I'm sure you can figure it out...see the image attached..I've used scatter to wrap 3 different water droplet mesh on the bottle.
good luck
Meher
http://www.mr-cad.com
