paul Posted January 5, 2006 Share Posted January 5, 2006 When I use vray to render one speedtree the render time is very slow and vray renders the faces of the tree so the output is horrible. Does anyone have a solution to this problem. Thanks for your help Link to comment Share on other sites More sharing options...
siliconbauhaus Posted January 5, 2006 Share Posted January 5, 2006 In all honesty the best solution is NOT to use speedtree with VRay. There have been numerous posts on the VRay forum about speedtree and all of them involve a lot of workarounds. If you really need to use speedtree, why not render the trees out as a seperate scanline pass and comp the images together? Link to comment Share on other sites More sharing options...
paul Posted January 5, 2006 Author Share Posted January 5, 2006 I do alot of large number of master plans I kind of require to figure this one out. But great advice, I´ll probably use your suggestion. thanks Link to comment Share on other sites More sharing options...
