viewport problem
only3d
hi evrybody, ive imported a model from ACAD (using 'linked dwg') as i did many times before but this time the model kinda "breaks" in viewport mode. it doesnt bother me when i render but it does bother when i want 2 work on my model so any ideas will b welcomed.
tnx - on
(using max 7)
Try the software display mode and see if the problem persists. If not then see my post in this thread for what drivers and display mode to use. If it still does occur in software mode than it might be a possible bug, so send us a screen capture or better description of the issue and I might be able to point you in the right direction from there.
instaed of linked dwg, try importing the dwg... see if the problem still persists. this will help u narrow down ur problems to graphic displays or software/file errors... :rolleyes:
Mandeep,
Technically there’s nothing really different between the dwg import code vs. the filelink code (unless you use legacy dwg import) and this really doesn’t tell us (Autodesk technical support) if there’s a graphics problem or not. Switching to software display mode is the first thing that should always be done if suspecting a graphics driver or display problem. This forces the viewport draw loop to go through the cpu and not the gpu so it rules out any driver possibilities.
hi again
i dont think its a driver thing either. but i think it might have something 2 do w 'clipping' cuz when i fiddled w the viewport clipping and FOV it pretty much solved the problem so i think that might b it.
anyways im good 4 now but still tnx 4 the help
oh and btw- ive seen this on someones pc but i dont know how he did it but when he panned or orbitted the model it went to wireframe mode and back automatically. that could b very usefull in my case so if anyone knows how 2 do it thatll b great
again tnx
