siliconbauhaus Posted January 9, 2006 Share Posted January 9, 2006 This is a really basic question. I'm getting ready to learn modeling in max ( I've always used acad ) and I'd like to know what the euquivilent to the acad UCS is and how you go about using / modifying it? Link to comment Share on other sites More sharing options...
Brian Cassil Posted January 9, 2006 Share Posted January 9, 2006 That would be the "reference coodinate system", and to a smaller extent the "pivot point" or "pivot point center". The two kind of work in harmony with each other. Experiment with those and you should get the hang of how they behave. Link to comment Share on other sites More sharing options...
davistalexander Posted January 10, 2006 Share Posted January 10, 2006 helper panel> grid...is the equivilent of the ucs... also turn on the autogrid checkbok when creating new primitives davis Link to comment Share on other sites More sharing options...
siliconbauhaus Posted January 10, 2006 Author Share Posted January 10, 2006 cheers, I'll have a look into those. Link to comment Share on other sites More sharing options...
Sketchrender Posted January 11, 2006 Share Posted January 11, 2006 Hi Can I ask is it possible to set up a model with ordinace survey data, so it is accurate , heights, and position globally, for enviromental impact studies. I know it can be done in autocad, but how do you achive this in max 7, as I would like to do eveything in max. Thank you phil Link to comment Share on other sites More sharing options...
