r_mc_gowan Posted January 15, 2006 Share Posted January 15, 2006 im looking for some tutorials for max on exterior lighting casting into a buildings interior. can anyone point me in the right direction?? Link to comment Share on other sites More sharing options...
ecastillor Posted January 16, 2006 Share Posted January 16, 2006 check out the tutorials included in max Link to comment Share on other sites More sharing options...
ajvbochove Posted January 16, 2006 Share Posted January 16, 2006 Is it easier done with Mental Ray? Or should I use the Default Scanline render? I went directly to MR with the learning of Max, but it's difficult in this kind of lightning. Area Lights at every window ain't the solution when you look from interior to the outside, isn't it?. Link to comment Share on other sites More sharing options...
chuck Posted January 16, 2006 Share Posted January 16, 2006 I'd look at max's radiosity. It can be a bit tricky, and watch the color bleed. The tutorials do a fair job of expaining it... Link to comment Share on other sites More sharing options...
ecastillor Posted January 16, 2006 Share Posted January 16, 2006 or go with vray Link to comment Share on other sites More sharing options...
pixelperfectg Posted January 16, 2006 Share Posted January 16, 2006 You can also take a cue from the Vray guys and work in a linear workspace (change Max's default gamma from 1.0 to 2.2). And it helps even the light out in MR. Here's a quickie lighting test using 2.2 gamma: http://www.jeffpatton.net/temp/exterior-tst.mov Nothing fancy I know, but render time was a little over 1 minute per frame...and this is straight out of 3dsmax no tweaks (video compression hurts quality a bit). One MR spotlight for the sun, and one skylight. Plain, simple, but effective. I've compiled more info on the linear settings here: http://www.vizdepot.com/forums/showthread.php?t=3465&highlight=linear and in that thread I've included links to the original info on linear workflow. Jeff Link to comment Share on other sites More sharing options...
