REAL world units??? (cm/inch..lux...etc)
Zdravko Barisic
I've been looking for this answer for almost 2 months but I did find NOTHING, well:
-If I have new max scene with international units Vray assume that is metars or centimetars?
-If I have one Direct Light what is its candellas or Lux units?
(or Vraylight instead of it?)
So what are Vray primary units? Its so confusing working with "unitless" program, isnt it?
Wow, half the people on that thread are incredibly confused :) But after sifting out the confusion there's very helpful info in there. The way I read it is basically, Vray assumes you're in meter and if you normalize the lighting intensity the unit is watts. Convert lumens to watts by multiplying by 0.0015, and keep in mind that you might actually be working in watts per square meter if you're using VrayLights. (Is that correct?)
Yeap.. sounds correct... to be brutally honest, since vray does not really have exposures like the radiosity engine, I just light it until it seems correct. I only care about the intensity relative to the other lights. But I work differently than you guys.
I'm with you on that - I'm not likely to be using Vray for accurate lighting simulation, and I'm used to the non-normalized units - I find it pretty easy to eyeball a situation and say "that should 3 0.5's on that side" etc., and not miss exposure control. But it's nice to know that if it really needs to be a 100W light bulb, that's possible.
  • 18 years later...
