Arch Window
Jago_0108
Hi there I have a very big problem with arch windows, the thing is that i create a poly line closed by an arch, then extrude it, extrude the line thats supposed to be the wall and then substract the "arch window" hole from the "wall", when i link the file into Viz 2005 the archwindow instead of being an arch with many segments, smooth and "circular", becomes an arch of three points, how can i improve this.
If you are using File Linking, there is a way around this. After linking the model go back to the file link menu and click files. Then hit reload and you will get a dialog box. On the bottom right there is something about surface deviation or something like that. Change it to .1". This should smooth out the surfaces.
Thanks for your help I tried both advices but could not get the results I wanted here is an image of the problem I mean, could it be the type of arch I'm doing in Acad? If so, what kind of arch should I do to get more points in the curve? Thanks for your help.
The red one is the one linked with the file link manager from acad.
The other is a window i tried to fit in it but the number of points in the arch did not coincide
