d7man2000 Posted January 20, 2006 Share Posted January 20, 2006 How to render regions, not whole image with vray? Link to comment Share on other sites More sharing options...
ccouto Posted January 21, 2006 Share Posted January 21, 2006 yes, you can do that, if you are using the virtual frame bufer from vray you must check the "get resolution from max" Link to comment Share on other sites More sharing options...
martincg Posted January 21, 2006 Share Posted January 21, 2006 you do not need switch to v-ray frame buffer - just switch in main toolbar from view to region render. /if you want to use vray frame buffer you could, but resolution have to be same like in max frame buffer/ Link to comment Share on other sites More sharing options...
d7man2000 Posted January 23, 2006 Author Share Posted January 23, 2006 but when I switched to region, vray calculates the whole scene Link to comment Share on other sites More sharing options...
ipdesigner Posted January 23, 2006 Share Posted January 23, 2006 d7man2000 said: but when I switched to region, vray calculates the whole scene *it is, thats how Vray works:) Link to comment Share on other sites More sharing options...
Sketchrender Posted January 23, 2006 Share Posted January 23, 2006 Hit the render icon and not F9, then it will show you a dotted lined box and adjust it to what you want and then hit ok in the bottom right hand corner. phil Link to comment Share on other sites More sharing options...
brvitorino Posted January 23, 2006 Share Posted January 23, 2006 hi d7man2000, to render a region u need to calculate the irradiance of the view and save it, them select (in irradiance mode) from file, browse to the saved file, and render the region you want. I hope this helped Link to comment Share on other sites More sharing options...
