cain Posted January 22, 2006 Share Posted January 22, 2006 Hi guys, This is my first post and I was hoping for some advice. I am using Autodesk viz 2006 daylight with radiosity at 60%. Could someone tell me how to make shadows more realistic and how to make the prints on the wall look like they aren't floating? thanks, cain Link to comment Share on other sites More sharing options...
Ismael Posted January 23, 2006 Share Posted January 23, 2006 I am still on Viz 4 but probably the "meshing" of the Radiosity solution is too coarse. The finer it is the more shadow detail, specially smaller shadow details. Search this forum and you will find just about everything about Radiosity; among other things. By the way, 60% is just about only good for preview purposes. Ismael Link to comment Share on other sites More sharing options...
ecastillor Posted January 23, 2006 Share Posted January 23, 2006 this is probably due to that 60 % quality..increase that one....also make your materials super sample to get rid of those jagies Link to comment Share on other sites More sharing options...
cain Posted January 23, 2006 Author Share Posted January 23, 2006 thanks guys, I will definitely increase the radiosity. Is there anything else I could change. What shader would you use for wall materials? I used a diffuse white for my walls but they turn out beige. Is it a reflective issue from the wood floors? How do I fix this problem? I am still learning viz and I could use all the help I can get. Link to comment Share on other sites More sharing options...
Ismael Posted January 23, 2006 Share Posted January 23, 2006 That "beige" color thingy is called color bleed. Has to do with Reflectance. Do the tutorials that came with Viz. Also look at the tutorials by Ted Boardman, right here on this forum. There are other tuts here too from Montree T. and others: http://www.cgarchitect.com/upclose/TB/default.asp http://www.cgarchitect.com/resources/tutorials/default.asp Those will give you a good going set for starters. Cheers, Ismael PS Some more links: http://usa.autodesk.com/adsk/servlet/autoindex?siteID=123112&id=2253423 http://www.viz2000.com/html/link/viz-link.html Link to comment Share on other sites More sharing options...
Jonathan Sanchez Posted January 23, 2006 Share Posted January 23, 2006 Also you might want to give the glass some reflection. If you fix this image, it will be a good use of interior radiosity. Link to comment Share on other sites More sharing options...
Ismael Posted January 23, 2006 Share Posted January 23, 2006 So you will not have to look through like a gazillion tuts just to improve and get a good grip on Interior daylighting, just check this one: http://jan.brookes.com/ And follow the links to the :Viz 4.0 Global Illumination Tutorial (Daytime Interior Scene) GI Tutorial. Ismael Link to comment Share on other sites More sharing options...
