can *.bak be created in a diff file folder than the dwgs
RAYMOND
When you open a DWG file stored in a folder, work with it and then save it, that DWG is renamed to BAK and a new drawing with the same name as the original is created. Therefore the BAK is in the same folder. It's not moved after that.
Why do you need to hide BAK files? To protect data in case of accidental file delection?
well when you have a folder with a lot of dwgs in it
be nice if those baks are somewhere else just for real estate purposes
for example one folder for dwg another for bak
i rarely open a bak... its just extra clutter...
tho having them is critical.. just that they are in the way...
i know just being cranky...:D :D :D
Ray
i religiously (as in always) create a separate bak folder for every project
and move the bak files into This folder several Times during The day
just in case The dwg file gets corrupted you can go back To The bak
file
This keeps The current directory cleaner
and it also gives you an extra backup file per dwg
i have had To rename a bak file back into a dwg from Time To Time
it can be a Life saver
Randy
Ray
maybe you could undefine The save command
To add a "dos shell" command To move *.bak To a specified sub/folder
just an idea
i dont remember dos or xdos shell commands off of The Top of my pointed head
does anyone remember "edlin" ??
(my all Time favorite Text editor)
Randy
i think your idea is the only one that will work...
think lisp has some dos commands..
edlin.... oh the painfull memories.. at UCSD monitored off of a CRAY super computer... thot it was wonderful then ... what a hassle tho to program.
had to take the elevator 7 floors down just to get to the printer..
yep, got to get those bak file in another room somewhere...
Hello!
In ADT at the command prompt, typ in MOVEBAK and it will ask for a "new value" which is where you want to type in the new location. You will need to create the folder first if it doesn't already exist as it will not create it on it's own, and will return to default behavior if it can not find or connect to the path.
Hope this does what you need!
Bytor
