how do you switch camera's in track view
RAYMOND
I believe you need Video Post for that, which is a feature missing from VIZ that Max has -- at least I don't see it in Viz 2005 (not sure about 2006).
You probably know this but you could render out a range of frames from each camera and then piece the renders together in a video editor. Even Windows Movie Maker will work in a pinch. I would be interested in hearing if there's a quicker method for VIZ. Maybe a script?
Additional suggestions have been made before:
http://www.cgarchitect.com/vb/showthread.php?t=2401
www.scriptspot.com has a camera animation script. really easy 2 use for changing camera.
personally id rather render each camera seperatley, then edit all the animation in a post production package such as after effects.
basically i always render out to jpgs.. then round them up in RamPlayer..
that way if a couple frames don't work or the render stops in the middle of the night i don't have to redo it from the beginning... however if need views from several camers i would need different file namses for the jpg output like camA_???.jpg CamB_???.jpg etc...
i use Window Movie Maker for Post Prodution...... primative as it is. mostly i use it for the compression so i cam email the wmv's
i will see what i can steal for the script writers at large...
thank goodness its monday...
