radioVOY Posted January 27, 2006 Share Posted January 27, 2006 Im a user of Photoshop V7 since it was launched, but now i saw some nice features in their CS2 release and I'll like to try it, but there is an issue: When you save a targa *.TGA with a transparent layer Pshop 7 reads the transparency as an alpha chanel, so i use this feature a lot to import texts to my videos on After Efects, text that you can save with a shadow drop that look smooth and very good on videos and without dealing with mask layers. But with Pshop CS when you save a targa with a transparent background and you impot it to another program, CS do to the transparency the same as you was saving a JPEG: you have a text but with a withe background, I dont know if is an option that you can disable, i need my alpha chanel without masking. So if anyone knows how to disable this feature in Photoshop CS and i can make to Photoshop to reads transparent backgrounds as an alpha chanel in TGA's please share. Thanks in advance for your replies. Link to comment Share on other sites More sharing options...
BrianKitts Posted January 27, 2006 Share Posted January 27, 2006 select your layer transparency (select-> load selection-> layer X transparency) then go into your channels panel, add a new channel the first one it creates is by defualt the alpha channel. Use the fill tool to fill the channel with the appropriate white/black and then save the image as a targa (use the selection box for save alpha)... it should work as it did before for you. Link to comment Share on other sites More sharing options...
radioVOY Posted January 31, 2006 Author Share Posted January 31, 2006 Thats the issue, with Ph7 to have a alpha channelk in targa you just had to set your bacground as transparent and everything but the upper layers would be transparent. Link to comment Share on other sites More sharing options...
gfa2 Posted January 31, 2006 Share Posted January 31, 2006 have you tried different file formats that support transparency? like .png? Link to comment Share on other sites More sharing options...
radioVOY Posted February 1, 2006 Author Share Posted February 1, 2006 yes the same result Link to comment Share on other sites More sharing options...
