ki_cz Posted January 29, 2006 Share Posted January 29, 2006 I've been using 3ds max for a lot longer than this question probably lets on, but it's a function that I've always worked around and never really had a 100% use for ... now, with roof shingles, I need it ... Q: how can I snap to the edge of a object when cloning? Like say, I have a box, and would like to clone it 10 times, and have the edges touching. Up until this point I've never really had the need to do a tonne of objects and have just used alt-a (align) to do it 'manually'. :confused: Thanks!! Link to comment Share on other sites More sharing options...
notamondayfan Posted January 30, 2006 Share Posted January 30, 2006 u cud try cloning it once, then align, then clone both, and align, then clone all 4, and align, so u basically only align 4 times, instead of 10. Link to comment Share on other sites More sharing options...
Tella Posted January 30, 2006 Share Posted January 30, 2006 Let's say we have to clone the box: select it > turn on snaps to vertex with "S"(RMB on snaps button to set it to vertex only) > lock selection hitting space or with the lock button (botton middle) > while pressing "shift" drag from one vertex to the other and release > in the clone options window select the number of copies you want > the copies will move the same distance one from each other. Another way of doing this would be with tha array tool (Tools > Array) Cheers. Link to comment Share on other sites More sharing options...
