notamondayfan Posted January 30, 2006 Share Posted January 30, 2006 hey guys, a quick prob that has been buggin me this morn. i have 3 faces all that apear the incorrect colour. its basically a plane, ploy modeled, and then ive use a multi sub material for its texture. i have tried other textures, and sub object numbering, but still the colour apears. i have deleted and remade the faces several times, and im positive there arent any hiden back facing faces. by the way, im using max 6, with vray free, GI and 1 direct light. thanks, dean Link to comment Share on other sites More sharing options...
STRAT Posted January 30, 2006 Share Posted January 30, 2006 tried unifying sll the normals? Link to comment Share on other sites More sharing options...
notamondayfan Posted January 30, 2006 Author Share Posted January 30, 2006 jus tried that, and nothing. also 2 note, if i delete another face, along the same plane, then create a new one, this newer dark colour is applied 2 it too. Link to comment Share on other sites More sharing options...
STRAT Posted January 30, 2006 Share Posted January 30, 2006 in that case it sounds like your not quite doing your submaterialing correctly. try it as a separate object in it's own right without the need for subobject matertials and face numbering. Link to comment Share on other sites More sharing options...
notamondayfan Posted January 30, 2006 Author Share Posted January 30, 2006 right, i have tried deleting the faces, and replaced it with a seperate plane, but using the same coords. then i have used the same material, and its still loads darker. ive hidden everything in the scene, so theres def no shadows being cast on it. any ideas? Link to comment Share on other sites More sharing options...
STRAT Posted January 30, 2006 Share Posted January 30, 2006 have you tried making it a separate object (not connected) with new coords? how does that work? Link to comment Share on other sites More sharing options...
noi-pi Posted January 30, 2006 Share Posted January 30, 2006 .....perhaps the face has a different smoothing groups? You could check that one too. Link to comment Share on other sites More sharing options...
notamondayfan Posted January 30, 2006 Author Share Posted January 30, 2006 tried both them, and still nothing. when i move the verts by huge amounts, say to make the face 45 deg, instead of vertical, the face then becomes slightly lighter, but it ruins the model. Link to comment Share on other sites More sharing options...
