demo38 Posted January 30, 2006 Share Posted January 30, 2006 Just came across the noise reduction software posted on digg.com that appears to be pretty incredible. Thought it might help... http://www.greyc.ensicaen.fr/~dtschump/greycstoration/demonstration.html Link to comment Share on other sites More sharing options...
ecastillor Posted January 30, 2006 Share Posted January 30, 2006 I guess if you have to use a noise reduction software for the rendered images of any given app...mybe its time to change that app! Link to comment Share on other sites More sharing options...
Devin Johnston Posted January 30, 2006 Share Posted January 30, 2006 Noise is just a byproduct of how Maxwell works, there's nothing wrong with it and I would argue that a little noise will actually help sell your image by removing that "CG" look that many engines are famous for. Link to comment Share on other sites More sharing options...
ecastillor Posted January 30, 2006 Share Posted January 30, 2006 then I guess there is no point in using a noise reduction software or is there? Link to comment Share on other sites More sharing options...
DennisHolland Posted January 30, 2006 Share Posted January 30, 2006 Strike out! Link to comment Share on other sites More sharing options...
Devin Johnston Posted January 30, 2006 Share Posted January 30, 2006 then I guess there is no point in using a noise reduction software or is there? My point was that "some" noise is acceptable or even desirable in certain circumstances. I'm not trying to say that all the noise Maxwell generates is good but at higher sampling levels once most of the noise clears there may be some left that actually adds to the image. Using a noise reduction program is a quick fix that most Maxwell renderings need at this point, that doesen’t mean the software is useless. Link to comment Share on other sites More sharing options...
ecastillor Posted January 31, 2006 Share Posted January 31, 2006 I never said it was useless....its just not finished yet, thats all....Ill be the first to buyit when it finally works! Link to comment Share on other sites More sharing options...
smb Posted January 31, 2006 Share Posted January 31, 2006 I never said it was useless....its just not finished yet, thats all....Ill be the first to buyit when it finally works! No, you will not. Many people will have bought it before you. steff Link to comment Share on other sites More sharing options...
AdamT Posted January 31, 2006 Share Posted January 31, 2006 Noise is just a byproduct of how Maxwell works, there's nothing wrong with it and I would argue that a little noise will actually help sell your image by removing that "CG" look that many engines are famous for. Absolutely! And too, square leaves (no clipmaps) create a unique "look" that clients will die for. You'll have to beat them off with a stick when they see your sunlight-absorbing glass! Link to comment Share on other sites More sharing options...
AJLynn Posted January 31, 2006 Share Posted January 31, 2006 I prefer my noise added in post, that way I have more control Link to comment Share on other sites More sharing options...
ivox3 Posted January 31, 2006 Share Posted January 31, 2006 I prefer my noise added in post, that way I have more control who doesn't ...... originally posted over at NL forum sometime ago .....thought it appropriate. Link to comment Share on other sites More sharing options...
ecastillor Posted January 31, 2006 Share Posted January 31, 2006 touche! Link to comment Share on other sites More sharing options...
