darkblue_wire Posted January 31, 2006 Share Posted January 31, 2006 Dear All I have seen this image on a website i like the materials much could anybody tell me how can i get this glow (shadow) effect? ( with the red marks )is that from the materials or it is only photoshop effects or even of the light only ? some parts of the building have a gradient like effect . I am a v-ray user best regards Link to comment Share on other sites More sharing options...
darkblue_wire Posted February 1, 2006 Author Share Posted February 1, 2006 hellooooooo nobody knew ? Link to comment Share on other sites More sharing options...
IC Posted February 1, 2006 Share Posted February 1, 2006 I can't see any glow but the soft shadow effect you've highlighted is typical of radiosity lighting affecting a bump map. Link to comment Share on other sites More sharing options...
ecastillor Posted February 1, 2006 Share Posted February 1, 2006 I have to agree with IC...I dont see a glow Link to comment Share on other sites More sharing options...
BrianKitts Posted February 1, 2006 Share Posted February 1, 2006 I'm guessing here at what you're after... so I could be wrong, but if you're asking how to get the hard edged shadow close to the building, and then the falloff to blackness to the background...... thats done with controlling the parameters of the light. You can set the diameter/angle of the hotspot independently from the falloff of the light. The defined shadow is in the hotspot of the light, and the gradient is the product of the falloff. anywhere close to what you were after??? Link to comment Share on other sites More sharing options...
darkblue_wire Posted February 2, 2006 Author Share Posted February 2, 2006 Dera all thanks for all replies ok , you are all right . i want to say the smooth shadow effect i have a building with one direct light & i have copied this light & add projecting & shadow map (cellular) to the copy it gave me an effect near that but still need help a friend told me to applay v-ray light & use little siples to have this dark splotches Link to comment Share on other sites More sharing options...
IHAB Posted February 2, 2006 Share Posted February 2, 2006 as for the shadow map settings.. from the Shadow Map Parameters try changing the values of [bias,size,sample range] also u can remove the shadow map and use adv. raytrace shadows + skylight (adv lighting) beside ur direct light..[try this one] but note that all these settings are for scanline render as vray has different settings ..hope this helped Link to comment Share on other sites More sharing options...
darkblue_wire Posted February 2, 2006 Author Share Posted February 2, 2006 Hi thanks Ihab for your help but i am a v-ray user > best regards Mohamed Link to comment Share on other sites More sharing options...
ecastillor Posted February 2, 2006 Share Posted February 2, 2006 use area shadows Link to comment Share on other sites More sharing options...
Sawyer Posted February 2, 2006 Share Posted February 2, 2006 Or use a vray light but make it a sphere and play with the diam of the actual light itself (small crisp shadows the larger the light the larger penumbra). Link to comment Share on other sites More sharing options...
darkblue_wire Posted February 6, 2006 Author Share Posted February 6, 2006 dear all thanks for replies here is a part of the scene i am trying to render at the same way . i am still trying thanks & best regards for all Link to comment Share on other sites More sharing options...
