ki_cz Posted February 2, 2006 Share Posted February 2, 2006 There has to be a simpler way to making arches in a wall than having to use booleans, or pulling vertices?? Am I completely out to lunch here? I feel like an idiot for not knowing an easy way to do this ... Link to comment Share on other sites More sharing options...
Gander0 Posted February 3, 2006 Share Posted February 3, 2006 I'm sure lots of people extrude splines from elevational drawings, so booleans etc wouldn't be an issue. Otherwise i'd probably cut my editable polygon Link to comment Share on other sites More sharing options...
enigma Posted February 3, 2006 Share Posted February 3, 2006 i usually create an arc or the profile in elevation then extrude it afterwards. can't think of a much simpler way. Link to comment Share on other sites More sharing options...
Munz Posted February 3, 2006 Share Posted February 3, 2006 here are more ideas, create an arc spline, extrude it and add a shell modifier or create a tube, and in the options you can have it only go 180 deg or from 90 deg to -90 deg. the harder part is texturing it if it is brick. I always paint my own texture arches, but would like to know if others have better techniques? munz Link to comment Share on other sites More sharing options...
