henrybroadhurst Posted February 3, 2006 Share Posted February 3, 2006 Hello, I would really appreciate some tips on what can be done to work with autocad files in maya-can they be converted into something that maya can use? perhaps with a little scripting/ mel tricks or perhaps some conversion software from the net or is this just a dead end? Cheers, H Link to comment Share on other sites More sharing options...
jonosf Posted February 20, 2006 Share Posted February 20, 2006 Maya has a built in DWG/DFX translator (I havent used it much) but go to Windows> Settings/Prefs> Plug-in Manager and click the "load" button for dwgTranslator.mll and you should be able to Import a dxf file. Good luck! -jono Link to comment Share on other sites More sharing options...
henrybroadhurst Posted February 20, 2006 Author Share Posted February 20, 2006 Hey Jono, Thanks v much, I ll give that a whirl soon as I get a chance sounds good. Many thanks, Henry Link to comment Share on other sites More sharing options...
daviniti Posted October 25, 2006 Share Posted October 25, 2006 with Maya 8 this is already built in, but I still cant get it to import correctly. Did you have any luck? Link to comment Share on other sites More sharing options...
e3di Posted November 3, 2006 Share Posted November 3, 2006 Yes, you need to download directconnect from autodesks website. Link to comment Share on other sites More sharing options...
stylEmon Posted November 8, 2006 Share Posted November 8, 2006 Even that directConnect works like CRAP. Maybe there are a couple advances with Maya 8, but I have just resorted to downloading a plug-in that allows you to use the DWG translator in Maya 7.0.1 and later. That translator works better with CAD files than MAX does! I found the plug in on http://www.Highend3d.com Link to comment Share on other sites More sharing options...
e3di Posted November 9, 2006 Share Posted November 9, 2006 Wierd, I use every day an it works fine. Although all I use it for is importing dwg files to use as reference. Maybe if you are trying to work with the files it is different. Link to comment Share on other sites More sharing options...
stylEmon Posted November 16, 2006 Share Posted November 16, 2006 are you using 8? I noticed that with 7.0.1, the CAD files come in incomplete, or very unorganized. Many lines are in the outliner but not visible. That's why I resorted to the plug-in. Also, Yes, I like to work directly from the CAD lines. Less work, better... Link to comment Share on other sites More sharing options...
