jared_1978 Posted February 6, 2006 Share Posted February 6, 2006 Hi Please someone help. I need to render at 3508 by 2480 for an A4 300 dpi print. However when i go to render I get "Error creating Bitmap" and it won't render. It renders when I reduce the resolution down to 3000 by 2121 (same aspect). There is a lot of glass in the scene. Is there just a limit on the res. that max can render out to or is there some simple setting that I am missing here. I am using a 37 light rig set up to fake the skylight/global illumination to save time. Please help thanks Jared. Link to comment Share on other sites More sharing options...
roland Posted February 6, 2006 Share Posted February 6, 2006 Hey Dude, Had The Same Problem Before But When I Increase My Ram From 1gb. To 2gb. Then Everything Where Back To Normal........ Hope It Help...... Link to comment Share on other sites More sharing options...
jared_1978 Posted February 6, 2006 Author Share Posted February 6, 2006 Well I have 4 Gb of ram so that can't be it. Thanks though Link to comment Share on other sites More sharing options...
manta Posted February 6, 2006 Share Posted February 6, 2006 Try the BIGRENDER script, its worked for me in the past... Link to comment Share on other sites More sharing options...
GeraldH Posted February 6, 2006 Share Posted February 6, 2006 http://usa.autodesk.com/adsk/servlet/ps/item?id=5582404&linkID=5573345&siteID=123112 ...good luck. Link to comment Share on other sites More sharing options...
JayTee Posted January 15, 2011 Share Posted January 15, 2011 Here is a website I found with quick fixes for memory problems with big renderings: http://3d-visualisointi.blogspot.com/2011/01/vray-memory-error-problem-rendering-big.html Link to comment Share on other sites More sharing options...
alrawli Posted January 15, 2011 Share Posted January 15, 2011 I think he's managed to sort the problem. But ill ask him on Monday morning to check. :-) Link to comment Share on other sites More sharing options...
