camfran Posted February 6, 2006 Share Posted February 6, 2006 Another problem which has been perplexing me: I'm trying to set up lights for a covered courtyard scene. I have the cloth material a bit grey on Refractive so that some light comes through the cloth canopies. I also want the support wires to then lay a darker shadow, so there'd be a medium grey from the cloth, and darker stripes from the wires. However i'm having trouble -- it's either All or Nothing, as in the images below. It's the 'Affect Shadows' check box which controls the on/off behaviour, i've found. Any ideas how to reach a happy half-way house situation? Many thanks! Link to comment Share on other sites More sharing options...
camfran Posted February 7, 2006 Author Share Posted February 7, 2006 ... it seems somehow connected to the GI -- when i turn GI off, i get both semi-shadow from cloth and also the darker shadow from wires (with 'Affect Shadow' ON). Also i just saw that when i turn GI down to 0.2 i still get the effect ('Affect Shadow' ON) -- but the earlier test was only at 0.8. Hard to believe it would get blown out by such a low GI? Strange... any ideas? Link to comment Share on other sites More sharing options...
ShaunDon Posted February 7, 2006 Share Posted February 7, 2006 This is totally a shot in the dark and a total work-around if it even works -- but have you tried turning refraction off (to black) and changing the visibility in the Max object properties? I do this for quick exterior glass a lot of times to just get a hint of reflection without having to calc refractions, but it might be a solution in this case as well. First I'd try boosting the refraction depth -- anywhere from 20-50. That often times has a great impact on how much light filters through the material and may provide a more accurate effect. Good luck! Link to comment Share on other sites More sharing options...
Trick Posted February 7, 2006 Share Posted February 7, 2006 Have you tried mapping the opacity (not refraction !!) slot ? Link to comment Share on other sites More sharing options...
