Sergio Posted February 8, 2006 Share Posted February 8, 2006 Hi all, I do visualization for some time now. I was thinking how could make process quicker. What I usually do is inport cad drawing freeze and trace. Maybe it is not the best way, but in any case, during that I got some problems. For tracing i usualy use line tool. in that proces i usualy get some problems: 1. while using line tool, I miss intersection snap (from cad) in max. 2. during the redrawing, i zoom quite much, draw than zoom out to draw again. If i try to pan (with a middle button) line "jumps" out and stops, if you know what i meen, and then i got two options to start again, or make another line, attach, and weld. Is there a method for paning while drawing the lines in max. In cad that is quite "normal" you are drawing line, pan and than continuing with a next node... Best regards Sergio Link to comment Share on other sites More sharing options...
archkre Posted February 8, 2006 Share Posted February 8, 2006 To interactively Pan & Zoom in Max we have some keystrokes, which I don't remember now!([ and]for Pan or something like that!) Go to the list of keystrokes in your Max and you'll find them out! Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 8, 2006 Share Posted February 8, 2006 Go to Customize -> Preferences -> Viewport and turn Zoom About Mouse Point on. That will make your mouse scroll work like a point zoom, ie, your zoom will focus the mouse pointer. Since scrolling does not interfere with the line command, you can zoom in and out, even emulating pan with just a sroll. Link to comment Share on other sites More sharing options...
Sergio Posted February 9, 2006 Author Share Posted February 9, 2006 Thanks archkre! Thanks Rick! I already did those changes in customise a long time ago, and zooming in and out, but is so slow. If I rotate wheel on mouse it zooms in and out no problem, but if I press and move whole mouse (in order to pan) just stopes the line command. I suppose you can not compare to the cad, where that function is working ideally. Any other ideas, please. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 9, 2006 Share Posted February 9, 2006 You find that slow? I don't know, once you get the grips with it it's just as fast as the real pan... Link to comment Share on other sites More sharing options...
Sergio Posted February 10, 2006 Author Share Posted February 10, 2006 Rick, I think you are right, I just want to impruve my overall speed and quality lately, and maybe you can not save much time by doing this. As they say, don't use the force, pick a bigger hammer, LOL. Link to comment Share on other sites More sharing options...
