Modeling in Autocad
antonio_frias
What is your solid model like?
My model is a 10000 m² appartement building with 4 floors. There is alot of detail due to all the windows and balconys that I created.
I think that the problem with my model is that there is too much detail. I detailed all my sash windows and I should have made them much simpler.
Your model is very detailed and the file must be so large. However, you try on to reduce value of the next parameter: "isoline" - if you want to use extrude object and "surftab1" and "surftab2" if you want to use revolved or edge surfaces. Although, you must do this adjustment on the begining of work.
If you are getting into that much detail, then short of using X-refs there is no way around it. Ofcourse using Xrefs brings about a whole other set of probelsm that you have to deal with (espesially when it is time to make sections and actual dimensioned drawings).
Just in general AutoCAD starts to choke if the file becomes too big, so watch out. AutoCAD's age when it comes to stuff like this really starts to show through.
i agree with the xref idea.
divide the model into floors, roofs, interiors, etc...
then have a separate dwg where just xref parts are need...
you can alway align with xref also....
huge detail models all in one place are a pain basically
gets really hard to work on after a while...
you detial to a great extent but do it in separate models...
also if you are linking into viz this will load times much shorter.
r
salut ! ( i'm also french)
i'll continue in english for all the rest of the planet!
You have to work with blocks and wblocks... and xrefs.
You'll have lighter files and it will force you to modify a block to open an other session ( for the oldest autocad releases).
This hierarchy will be kept in 3dstudio as groups, it's convenient...
pierre-yves
