DAN212222 Posted February 9, 2006 Share Posted February 9, 2006 hi guys another noob question for yas... whats the best way of getting scaled autocad drawings into c4d? apply them as a texture? but then i struggle to see them? hmmm love some help dan Link to comment Share on other sites More sharing options...
Frosty Posted February 9, 2006 Share Posted February 9, 2006 convert to dxf Link to comment Share on other sites More sharing options...
Scott Baumberger Posted February 9, 2006 Share Posted February 9, 2006 I've had better luck exporting via the 3ds format - it keeps the files size down. Link to comment Share on other sites More sharing options...
eoghan Posted February 9, 2006 Share Posted February 9, 2006 i bring them into illustrator and use a plug in that imports/exports them to scale, then bring them in as ai files to cinema. then extrude and model from there. Link to comment Share on other sites More sharing options...
DAN212222 Posted February 10, 2006 Author Share Posted February 10, 2006 HMMM still haviing some problems has anyone ever come across any tutorials for this type of thing cheers guys dan Link to comment Share on other sites More sharing options...
DAN212222 Posted February 10, 2006 Author Share Posted February 10, 2006 when i try to import the dwf. file all i get is file unknown... error box... should i be loading this as a texture or is there someway of importing it? cheers guys dan Link to comment Share on other sites More sharing options...
Frosty Posted February 10, 2006 Share Posted February 10, 2006 dwf is proprietary autodesk. I dont think anything else will read it. If it is 2D geometry, try dxf as I suggested earlier. If it is 3D geometry 3DS may be more appropriate. Link to comment Share on other sites More sharing options...
egidio Posted February 10, 2006 Share Posted February 10, 2006 Hello! Sorry for changing subject, but I think this is a similar problem. I'm moddeling in rhino3d and exporting to 3ds to use it in cinema. Dxf works for me too, but its not so accurate than 3ds(missing polygons), but with 3ds I loose all my layers and groups. Is anyone found any better way for transfering mesh from rhino to c4d, without loosing layers and polygons? Link to comment Share on other sites More sharing options...
STRAT Posted February 10, 2006 Share Posted February 10, 2006 from rhino to c4d - i usually go via autocad first. from autocad to c4d - if its 3d then use .3DS all the way. if it's 2d then i wouldnt even bother. Link to comment Share on other sites More sharing options...
gdrakakis Posted March 25, 2006 Share Posted March 25, 2006 maybe you could try the Engineering Bundle. unfortunately, there is is no demo or trial available, but the info from Maxon looks quite promising. this is the link: http://www.maxon.net/pages/products/c4d/engineering/engineering_e.html it's based on Okino Polytrans import filters to import numerous CAD file formats. ps: i'd love to have some feedback from anyone that has used this module. Link to comment Share on other sites More sharing options...
J.C Posted March 26, 2006 Share Posted March 26, 2006 try 'PEDIT' and convert all linewrok to polylines then use the routine in this post http://discussion.autodesk.com/thread.jspa?messageID=1149493 to convert them to 3dpolys (there might be other routines out there), export to dxf. then just drop the dxf into c4d and all lines should be there as splines ready to be extruded and nicely grouped into groups according to your layers in acad just connect them as needed. works for me............. hope it helps, JC Link to comment Share on other sites More sharing options...
