how to animate a material, changing material from transparent to normal
d7man2000
Apply the material to your object and set the material's opacity to 0 (or transparency to 100).
Turn on AutoKey then go to the frame when you want the material to appear. Now go back into the Material Editor and change the opacity of your material to 100 (or transparency to 0).
You should get two new keyframes for the change in material property. The first key will probably appear at frame 0 and you may have to manually move it to the frame when you want the material animation to begin.
To fine tune, or to even do the entire keyframing process, you could open the Track View's Curve Editor or Dope Sheet. In either place you'll find your object and its material properties.
Example (Box01)
Box01
|_Material ##
|_(#): Material's Name
|_Extended Parameters
|_Opacity
a_w
