ham Posted July 24, 2002 Share Posted July 24, 2002 I came across this on the autodesk discussion forums and felt it was my duty to pass on the link for those that dont allready know about it. http://www.acmebrick.com/md/index.htm its a programme that makes photorealistic brick wall textures, its very detailed and best of all - free! Link to comment Share on other sites More sharing options...
superdave Posted July 24, 2002 Share Posted July 24, 2002 Have you used this and if so are the maps Tileable? Just Curious. Link to comment Share on other sites More sharing options...
ham Posted July 24, 2002 Author Share Posted July 24, 2002 Yes I have used it and yes the maps are tileable. You can specify the resolution of the texmap and how many bricks you want, the results are far more convincing than a procedural brick shader. Link to comment Share on other sites More sharing options...
Paul Griger Posted July 24, 2002 Share Posted July 24, 2002 I downloaded this program, very useful! I did try tiling and found that I had to adjust the pic to make it work. I just offset the pic in a PS knock-off, cropped it proper, and it worked great. It seemed to me that when I tried to adjust the width or height so that it was an uneven amount of brick in cols vs. rows, the width always included a half column of brick throwing things off to tile it properly right out of the box. I may be missing something. I don’t mind cropping it though…. Still a great tool none the less! Link to comment Share on other sites More sharing options...
nisus Posted July 25, 2002 Share Posted July 25, 2002 Impressive! Link to comment Share on other sites More sharing options...
STRAT Posted July 25, 2002 Share Posted July 25, 2002 Impressive! Link to comment Share on other sites More sharing options...
vizwhiz Posted September 6, 2002 Share Posted September 6, 2002 hi There, ham, check This out: go here for additional "Masonry Designer" Links: http://www.viz2000.com/html/3250softtext.html http://www.viz2000.com/htm0/0223-QUIK-EXTR-WALL-MAPS.html i like the McNear the best, more rustic and has some pavers if you are looking for some additional "free" real-world Textures check This out: INTR FLGR MAPS: Conc, Granite, Marble, Slate, Stone, Tile, Wood http://www.viz2000.com/htm0/0123-QUIK-INTR-FLRG-MAPS.html EXTR WALL MAPS: http://www.viz2000.com/htm0/0123-QUIK-INTR-FLRG-MAPS.html *** i posted these linked somewhere else today too so i want be anymore redundant Thanks Randy Link to comment Share on other sites More sharing options...
