GeraldH Posted February 12, 2006 Share Posted February 12, 2006 Has anyone had success in creating a scratch face blended brick material? I'd be interested in your process. Thanks. Link to comment Share on other sites More sharing options...
AJLynn Posted February 12, 2006 Share Posted February 12, 2006 Have you tried it with bump map? Use a normal brick bump map photoshopped to add the lines. You can use a specular map or go with displacement to get a stronger effect. Google acme masonry designer for a good tool for making the base brick maps. Link to comment Share on other sites More sharing options...
Tommy L Posted February 13, 2006 Share Posted February 13, 2006 If doing a large area of repetive material, I would always use a procedural material. You could try using the tile material in the diffuse channel, then putting a mix material in the tile material? You can use a tile material at the same scale as the orignal in the 'mix' parameter and randomize the two bitmaps you choose to generate endless non repetetive bricks. Drop me a line if that didnt make any sense and ill email you an example material. Cheers, Tom. Link to comment Share on other sites More sharing options...
