Dguarcello Posted February 13, 2006 Share Posted February 13, 2006 I currently use Autodesk Arch. Desktop 3.3 and Viz 4 for modeling and rendering respectively....I use it for school, and I do some work for my old boss (who supplied me w/ the software). Recently, the firm I used to work for upgraded to AutoCAD 2006, and as far as I know it is not backwards compatible w/ Desktop 3.3. I can get aCAD 2006, but will it work w/ VIZ 4? If not, what will work w/ it? Does 3DSMax work in a similar way? I can get that if needed, but otherwise, I'm 'up a creek'...... Link to comment Share on other sites More sharing options...
ARQ_TINO Posted February 13, 2006 Share Posted February 13, 2006 You can still use Viz 4, while using 2006... just save the autocad dwg file to 2000... Viz 4 is not compatible with 2004 dwg...but you can still use the file as long as it is saved as 2000 dwg format.. Link to comment Share on other sites More sharing options...
Dguarcello Posted February 13, 2006 Author Share Posted February 13, 2006 You can still use Viz 4, while using 2006... just save the autocad dwg file to 2000... Viz 4 is not compatible with 2004 dwg...but you can still use the file as long as it is saved as 2000 dwg format.. Is that true even while using AEC walls/windows/doors etc? Link to comment Share on other sites More sharing options...
ARQ_TINO Posted February 13, 2006 Share Posted February 13, 2006 as far as i knw..Yes...coz i've done it before...but im using extrusion not the AEC wall..etc.. but as far as you are using 2000 format, it is compatible wid VIZ 4.. anyway, why dont you try??? Link to comment Share on other sites More sharing options...
