Vray 1.09.03 going 1.47.03
thnieves
Hello my friends,
I'm having a huge problem updating from vray 1.09.03 to 1.47.03. Just look at the images below. The first one was made with 1.09.03 and the second with 1.47.03. All the settings are quite the same in both version, but I think i´m doing something wrong here. I'm trying to update so I can use distributed rendering. But with this kind of results won´t be possible.
Thanks for any help
(Tim's right) you have exposure control turned on. I use vray and I never use exposure control but every once in a while it gets turned on somehow and the renders come out looking like your second image. All you have to do is go into the exposore control panel (same panel as environment...right below it)
I'm pretty sure your exposure control got switched to logarithmic exposure. Switch it back to "none" and your image will go back to normal.
