Vray and ERCO lighting !!!
SCSIx
Hi All,
This is my first posting hop it helps, I am having hard time working with vray, I have an interior design project for a client. My problem with the lighting system of vray I am using ERCO light’s in my scene and it seems that I can’t get the bouncing effect on the ceiling. When using vray default lighting it works fine but with the ERCO system it show very dark ceiling!!!..radiosity dosnt work with vray !!!! … Please help (attached the vray.jpg and erco.jpg)
Abraham
Chris, if gamma correction was the problem, wouldn't it be a problem with the vray lights too?
Generally,
With my experiences using both Vray and radiosity, it is generally not necessary to up the multipliers for photometrics with radiosity. Spot lights are "stubborn" in Vray from my experience. I'm not comfortable whacking out the multipliers if an architect or interior designer is interested in seeing a realistic representation of the room's lighting design.
  SCSIx said:
Thanks all for the reply, I agree with Fran it seem vray doesn’t do any lighting calculation on the ceiling! It tweaked the multiplier to 400% and that’s what I got
OK try this...
Set your color mapping to gamma correction and set the bright multiplier to 0.4545
The reason that you don't see it in the vray lights is that the falloff is softer overall with area lights so that super hot core and quick falloff is not as apparent as it would be with point lights like the IES spotlights.
I have done a lot of experimenting with this, and generally speaking, when doing interiors you need to make sure that you are viewing your results in the correct gamma corrected space, or you have issues just like this.
In terms of Frans response about multipying the IES lights, she is right but generally there is no real exposure (like in radiosity) for that so if you want to be a purist you would have to render to an HDR format like HDRI or EXR and expose up using that. Also, if you did render to HDR or EXR you would not need the gamma correction. I cover that in my DVD.
Were you trying to use radiosity with Vray? That wouldn't work.
I tried gamma correcting your image in Photoshop and the ceiling was still black, and the render time suggests little or no GI calculation. What are your GI settings?
ies lights, especially spots, tend to bring a lot of energy to a small area. in my experience there is no way to get the image straight than to use max exposure controls. i know... ouch. anyway, either that or render an exr and make sure you are experienced correcting that one. i still find pshop cs2 has not enough tools for correcting float, so i often use exposure control even if it hurts a little. but ok, the image you get is nice, and thats all that counts in the end.
a.
ps: oh, just saw you are asking vray specific - then try vray exposure controls, from what i saw they are superiour to what you find built in in max.
  • 5 months later...
I have the same problem with my scene too!I think that vray has some difficulty with IES lights.but I agree with Chiristopher Nichols because I have seen his useful DVD about vray.It is perfect!but I think that mental ray is better for work with IES lights.It can produce very clear picture in this field.you can test it!
