lala18 Posted February 16, 2006 Share Posted February 16, 2006 Hi. Does any one could help me to create this texture in VRAY? I’ve not been able to get textile effect as well as should be. This is textill glass. First is resolution problem. As u can see this image, if choose one of this colour, in a low resolution. Then I’m from “Tiling menu” adding tile quantity. But then I’m getting other problem, so that I can’t get smooth surface, because the texture’s rugged light makes visible tiles’ edge while I’m trying to solve resolution problem. Pls help me. Thank u. Link to comment Share on other sites More sharing options...
Thablanch Posted February 20, 2006 Share Posted February 20, 2006 It is not a Vray issue, even a standard mat would give you this error. Tou need to make your reference image perfectly tileable in Photoshop, with the offset tool. Once it is perfectly tileable, your material will be displayed perfectly in max Link to comment Share on other sites More sharing options...
lala18 Posted February 20, 2006 Author Share Posted February 20, 2006 It is not a Vray issue, even a standard mat would give you this error. Tou need to make your reference image perfectly tileable in Photoshop, with the offset tool. Once it is perfectly tileable, your material will be displayed perfectly in max You absolutely right. I know that it doesn't depend on VRAY.Just for exact information I mentioned VRAY. I'll investigate ur tips. Thank u. Link to comment Share on other sites More sharing options...
