JeeWee Posted February 17, 2006 Share Posted February 17, 2006 Hi all there, I'm asking you the answer to my problem with making grass with vray displacement. It's a render with VRay 1.7 and max 7. The model is made in AutoCAD 2006 and imported with File link manager. Now when I render the scene the grass shows a hard line where one side shows a lighter shade of grass then on the other side. On the left side of the scene there is one and on the right side there are also two. Please help me because i finally made it through making real grass! http://www.xs4all.nl/~wijsman2/test01.jpg Jeroen Link to comment Share on other sites More sharing options...
JamesTaylor Posted February 17, 2006 Share Posted February 17, 2006 seems your attachment isn't working, try post another version for us to have a look at please! Link to comment Share on other sites More sharing options...
jow Posted February 17, 2006 Share Posted February 17, 2006 try adding a subdivide modifier and setting the size to about 500ish,(depending on the scale you are using). failing that, do a poly edit and clean up the model that way so the triangles are of even size. hope this helps. Link to comment Share on other sites More sharing options...
ecastillor Posted February 17, 2006 Share Posted February 17, 2006 post your displacement settings... Link to comment Share on other sites More sharing options...
quizzy Posted February 17, 2006 Share Posted February 17, 2006 looks like a smoothing issue. Try and apply a smooth modifier to the grass object. And do not turn on automatic smooth. Link to comment Share on other sites More sharing options...
JeeWee Posted February 17, 2006 Author Share Posted February 17, 2006 here are my settings: http://www.xs4all.nl/~wijsman2/vraydispl.jpg and this is a render when i turn the current preset on the Irradiance map to "Very Low" the other render is "MEdium" http://www.xs4all.nl/~wijsman2/test02.jpg Jeroen Link to comment Share on other sites More sharing options...
quizzy Posted February 17, 2006 Share Posted February 17, 2006 did you try the smooth modifier between the linked geometry and the first UVW map modifier yet?? Link to comment Share on other sites More sharing options...
JeeWee Posted February 17, 2006 Author Share Posted February 17, 2006 do you mean like this? Link to comment Share on other sites More sharing options...
quizzy Posted February 17, 2006 Share Posted February 17, 2006 did you try the smooth modifier between the linked geometry and the first UVW map modifier yet?? between the linked and the FIRST UVW.. the first modifier in your stack is the bottom UVW one... Link to comment Share on other sites More sharing options...
JeeWee Posted February 17, 2006 Author Share Posted February 17, 2006 no won't work Jeroen Link to comment Share on other sites More sharing options...
quizzy Posted February 17, 2006 Share Posted February 17, 2006 could you send me the autocad file with only the grass in it?? cause it really looks like a weld/smooth problem. Maybe the smooth doesn't work on linked geometry and you have to bine the mesh... just send it and i'll have a look at it.. Link to comment Share on other sites More sharing options...
JeeWee Posted February 17, 2006 Author Share Posted February 17, 2006 yes, here it is....sorry for the delay...had to eat my dinner first! Link to comment Share on other sites More sharing options...
quizzy Posted February 17, 2006 Share Posted February 17, 2006 yeah i'm having dinner in 20 minutes and after that beer in the pub, so your file has to wait for tomorrow then.... Link to comment Share on other sites More sharing options...
JeeWee Posted February 17, 2006 Author Share Posted February 17, 2006 i'ts all right, have a lot of fun tonight and thanks for the support so far. like to make some compliments on your web-site too... Jeroen Link to comment Share on other sites More sharing options...
quizzy Posted February 17, 2006 Share Posted February 17, 2006 I am just to nice a guy.... try merging this max file in yours, hide your grass first. Apply the modifiers again and see what happens.... Link to comment Share on other sites More sharing options...
JeeWee Posted February 17, 2006 Author Share Posted February 17, 2006 well, there is some change...but not enough... Link to comment Share on other sites More sharing options...
JeeWee Posted February 17, 2006 Author Share Posted February 17, 2006 here's a solution, in autocad i don't extrude the object but leave it as a region, the only problem that sometimes occure is that there is a light at the edge of the grass. but that seems not to be the problem right now Jeroen Link to comment Share on other sites More sharing options...
