ZFact Posted February 18, 2006 Share Posted February 18, 2006 Thinking about buying something like this to run Cinema 4D.. What you guys think? Adequate? AMD 64 X 2 Dual core processor 4200+ 2Gig Ram Quadro FX 540 Graphics card 450 W power pack XP Pro Link to comment Share on other sites More sharing options...
AJLynn Posted February 18, 2006 Share Posted February 18, 2006 That looks good except for the video card - the 540 isn't very good. If that's what the budget is, you're probably better off with a good gamer card. Link to comment Share on other sites More sharing options...
voltaire_ira Posted February 18, 2006 Share Posted February 18, 2006 i suggest running it with xp64 rather than xp only..cinema4d i think is 64bit ready...you'll get the most of your ram when 64 bit os is used. i have 2 dual processor systems, 1 is a dual xeon 2.4's with HT running 32bit windows and the other is a dual opteron 275 dual cores running xp64...opterons has a clock speed of 2.0 ghz...but its 64bit already so it renders much faster compared to supposedly a faster xeon runnning at 2.4ghz(its even overclocked to 2.6 ghz)... Link to comment Share on other sites More sharing options...
AJLynn Posted February 18, 2006 Share Posted February 18, 2006 I don't think the Xeon 2.4 is even "supposedly faster" - you can't compare closk speeds of Intels and AMDs. I'd say multiply the AMD by 1.5 but that's not even consistent - the cache size also affects the equivalency rating. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 18, 2006 Share Posted February 18, 2006 ...for me cinebench ran 30% faster when using the 64 bit version. i would assume that would translate to cinema 4d. also, if you go 64 bit, you will need the 64 bit version of cinema. the 32 bit version runs about the same speed regardless of whether the operating system is 32 bit or 64 bit. Link to comment Share on other sites More sharing options...
