alfienoakes Posted February 21, 2006 Share Posted February 21, 2006 Hey ... I have used some Erco lights in my scene, first time.. and they look good. Renders no probs on my machine. but when I try and network render, the servers cannot find the *.ies map files..! I have copied them to a common network directory, added paths etc, copied them to the client machines.. and still the same message. Now I have set up hundreds of network renders, with multiple map files etc.. and as long as you tell the manager machine where they are, or copy all files required to each server machine, it works fine. But not with the erco ies files?? Has anyone any clues..? Cheers Andy Link to comment Share on other sites More sharing options...
Aksel Posted February 21, 2006 Share Posted February 21, 2006 hi andy, erco lights dont use any technology unusual to max, and that is photometric point lights and idroppable content. the idrop content including the ies-file is always put automatically into ...\3dsmax\downloads, so you might want to try and copy your files from there to another directory. to avoid that i keep my ies-data on a network drive and exchange the ies path in the light manually. you have to do that anyway, i.e. opening old project, reinstalled max, download-folder gone. hope that helps, aksel. Link to comment Share on other sites More sharing options...
JamesTaylor Posted February 21, 2006 Share Posted February 21, 2006 maybe try mapping them using a UNC path rarther than just thro mapped drives Link to comment Share on other sites More sharing options...
Tim Saunders Posted February 22, 2006 Share Posted February 22, 2006 i've had a similar error, not with net rendering though. to fix my problem, i just made sure i hade the files named what i wanted them names and saved on the network where i wanted them saved, then in viz, i clicked the distribution button again and re assigned the newly named light file to the light. that fixed my problem, and i bet it would fix yours too. seems wierd, but you may have renamed or replaced your ies files after you assigned the data to a particular light. i still love your avatar! Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 22, 2006 Share Posted February 22, 2006 you avatar freaks me out. go to... File | Asset Tracking | scroll down to your Photometric file list, and check or specify the file path on the common network. hopefully that helps. ______________________- edit: this is what i would do if you were in max. ..it might be th same for viz. Link to comment Share on other sites More sharing options...
alfienoakes Posted February 22, 2006 Author Share Posted February 22, 2006 OK.. Cheers guys for the help.. I went home and realised that the best course of action, was to put the files on a network drive, then try it.. still didn't work.. So, I went into each light, opened the light assembley, modifiy panel, then you can pick within the lights properties, where the IES file is..Probably what Tim was saying.. Anyhow.. all working like a dream now..! Cheers Andy PS - I am pleased my avatar is a good source of discussion..! Link to comment Share on other sites More sharing options...
abicalho Posted February 23, 2006 Share Posted February 23, 2006 The easiest solution is to enable the option that includes maps with network rendering - it will then zip all maps, IES files, etc, into a single package and will send it to the manager for rendering. Link to comment Share on other sites More sharing options...
alfienoakes Posted February 23, 2006 Author Share Posted February 23, 2006 Cheers Alex, That is definately worth considering the next time I am panicing....! Andy Link to comment Share on other sites More sharing options...
Devin Johnston Posted February 23, 2006 Share Posted February 23, 2006 The easiest solution is to enable the option that includes maps with network rendering - it will then zip all maps, IES files, etc, into a single package and will send it to the manager for rendering. I do this with every network job I send out, that way I don't have to worry if all my maps and files are visible by the network or not. Link to comment Share on other sites More sharing options...
alfienoakes Posted February 24, 2006 Author Share Posted February 24, 2006 OK then.. Maybe upgrade "next time I am panicing" to "next time I do one"..! Cheers guys Andy Link to comment Share on other sites More sharing options...
