d7man2000 Posted February 22, 2006 Share Posted February 22, 2006 what settings do you apply to exterior scenes? Link to comment Share on other sites More sharing options...
Thablanch Posted February 24, 2006 Share Posted February 24, 2006 Usually, one light for sun, and HDR map in Environment as light emmiter and reflection... Does it most of the time Link to comment Share on other sites More sharing options...
erevan Posted February 24, 2006 Share Posted February 24, 2006 Same as Thablanch. But still waiting for HDRIs that project reliable shadows. In an old thread someone mentioned the improving to be done in VRay new versions. Link to comment Share on other sites More sharing options...
jtiscareno Posted February 24, 2006 Share Posted February 24, 2006 For a basic setup get a sunlight or a direct light (have never liked the daylight system) uncheck the defauly light in the global switches, and turn on the GI Enviroment (pick any color or map for your skylight) and you are preatty much ready. You might want to follow this two tutorials by the osmosis group, really good! www.osmosis.com.au (go to the tutorial section) good luck Link to comment Share on other sites More sharing options...
gnuhong Posted May 2, 2006 Share Posted May 2, 2006 Usually, one light for sun, and HDR map in Environment as light emmiter and reflection... Does it most of the time dont you feel hdri change the color of our scene too much? i feel that hdri environment cast too strong color. Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 2, 2006 Share Posted May 2, 2006 dont you feel hdri change the color of our scene too much? i feel that hdri environment cast too strong color. Not if you work in the correct colorspace Link to comment Share on other sites More sharing options...
kippu Posted May 2, 2006 Share Posted May 2, 2006 Not if you work in the correct colorspace and by that you mean use gamma correction / exponential? Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 2, 2006 Share Posted May 2, 2006 Yes sirre.... http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=10854 Basically your viewport is set with a low gamma and needs to be corrected. Low gamma means your images is not only darker, but also more saturated. When you gamma up the viewport, not only do you brighten your blacks, but you also desaturate them slightly. Link to comment Share on other sites More sharing options...
kippu Posted May 2, 2006 Share Posted May 2, 2006 oh boy if i got a dollar for everytime i read those forum pages i be a very rich man indeed..anyway i havenot tried that way for exteriors till now Link to comment Share on other sites More sharing options...
