Image resolution?
antonio_frias
resolution? 72 dpi is fine for every thing. you can always render at a higher pixel rate (still at 72 dpi) if you intend to do final printing at a later date.
dont let pixel res, dpi and image size confuse you.
usually -
printing size - printsize (inches) X DPI = pixel render size
so for example, to print and image at A4 at 300 dpi -
A4 (11.693 inches) X 300 = 3508 pixels.
so at 72 dpi you render at 3508 pixels wide. this will equate to A4 @ 300 dpi when resized in photoshop
The best thing to do would be to use the Print Size Wizard in the rendering menu pulldown. You can specify all sorts of print presets and adjust the dpi.
Also, you'll want to save the file in a *.tiff format so that you can specify the dpi. Otherwise, you'll have to resize it in Photoshop or whatever other image software you choose to print from
