blounder Posted February 26, 2006 Share Posted February 26, 2006 fixed Link to comment Share on other sites More sharing options...
AJLynn Posted February 27, 2006 Share Posted February 27, 2006 I highly recommend that you send this image to Maxon customer support. They will be better able to explain where you've gone wrong. Link to comment Share on other sites More sharing options...
William Alexander Posted February 27, 2006 Share Posted February 27, 2006 Me too, think it's a XP/Microsoft update issue. I had an auto update pending, was working with C4D closed things down to restart....and C4D would'nt start after. Starts just fine on the w2k system, no updates. Also got the BS system won't allow you to open, blah blah blah with PS's help documentation.....very well could be a setting was cahnged that interferes with C4D & it's network pings looking for other instances running. WDA Link to comment Share on other sites More sharing options...
William Alexander Posted February 27, 2006 Share Posted February 27, 2006 It's back running..... What I did change was delete the google & yahoo tools bars....thanks TimeWarner and adobe PDF #$%^&*(), and disabled the pop-up blocker that came with those. Restarted----did not get that error, got the default microsoft one. One of the modules was opengl32.dll...searched them down the one in use is about 9months old...OK...went to start Max...MR plugin was throwing errors and MR did not load...SOB....time for the sledge hammer....turned the Box off and let it sit for a bit.... started back up...no problems. Can't say that it'll fix your problem....but check into updates on your video drivers if you can't find a solution...along with contacting Maxon, they are really good about following up Cheers, let us know how it turns out WDA Link to comment Share on other sites More sharing options...
AJLynn Posted February 27, 2006 Share Posted February 27, 2006 Actually, what's most likely to fix his problem is to get the most recent Maxon release instead of the Paradox version. Link to comment Share on other sites More sharing options...
blounder Posted February 27, 2006 Author Share Posted February 27, 2006 Could anyone give me a link? Link to comment Share on other sites More sharing options...
AJLynn Posted February 27, 2006 Share Posted February 27, 2006 http://www.maxonshop.com/cgi-bin/row/gp?pg=products.software&sid=&uid=&aid=&cid=100&rn=231 Link to comment Share on other sites More sharing options...
blounder Posted February 28, 2006 Author Share Posted February 28, 2006 So I would need to buy a new version of C4D or is it free? Link to comment Share on other sites More sharing options...
AJLynn Posted February 28, 2006 Share Posted February 28, 2006 It's commercial software, you need to buy it - then you can get tech support. Dude, your screen cap contains the logo graphic of a software piracy group. If you've got a legit copy, and there's some other reason for the graphic, then contact Maxon tech support. If you don't, then having a hack copy is probably part of the problem. It's a relatively inexpensive package, even more so if you're a student, and it's worth buying. If you're not sure, there's a free demo on the Maxon site. And even if software piracy discussion weren't banned on this board, there isn't much help we could give you with this kind of thing. Link to comment Share on other sites More sharing options...
