Drunkenbear Posted February 27, 2006 Share Posted February 27, 2006 ok i think i pressed something by accident and now i cant move objects using xyz constriants when i select and object the yellow, red, green XYZ dont appear. I can move the object but cant constrain which direction any ideas on how to get the cursor back? cheers Link to comment Share on other sites More sharing options...
MandelbrotJr Posted February 27, 2006 Share Posted February 27, 2006 If you are using Max, just press the X, that will bring the Gizmo back. Best Regards Link to comment Share on other sites More sharing options...
Drunkenbear Posted February 27, 2006 Author Share Posted February 27, 2006 knew it was somthing stupid like that cheers Link to comment Share on other sites More sharing options...
gvisual2005@yahoo.com.sg Posted February 27, 2006 Share Posted February 27, 2006 u can go to preference then, look for gizmo, then check it Link to comment Share on other sites More sharing options...
arkiedmund Posted February 28, 2006 Share Posted February 28, 2006 I have a similar problem...though quite different. everytime i switch to a viewport, some object get highlighted, i always have to press j to turn that highlight off. What is the j key for in max? Link to comment Share on other sites More sharing options...
ipdesigner Posted February 28, 2006 Share Posted February 28, 2006 *what do you meant by highlighted? *first thing first, you have to check your UI (User Interface). Go to Preference then 'Customize User Interface', check they 'Keyboard'. Look for the shortcut 'J' to where it is used for as an action, you can remove or reassign it if you want. Here you can customize whatever keys you want. Link to comment Share on other sites More sharing options...
kdavenport Posted March 1, 2006 Share Posted March 1, 2006 The "j" hotkey toggles the bounding box on and off Link to comment Share on other sites More sharing options...
