cain Posted March 3, 2006 Share Posted March 3, 2006 Hi guys, I was wondering if I can't use radiosity if I am using photometric lights? I have gone through the tutorials and radiosity works fine for my daylights and standard lights, but if I use it on the preset photometric lights I get a messed up rendering with triangles and dark objects. Also, if I use the daylight system in the scene, my photometric lights don't work. The scene I am rendering is a small lobby with very little windows. If any of you have any suggestions on how to light this scene I would really appreciate it. Link to comment Share on other sites More sharing options...
a_w Posted March 4, 2006 Share Posted March 4, 2006 Sure, you can use photometric lights with radiosity. The following comes from the Autodesk VIZ 2005 User Reference. It's about Radiosity Workflows: Physically Based Workflow Lights: Photometric Lights Daylight: IES Sun and IES Sky Exposure Control: Any Units: Make sure your scene is set to the appropriate scale. Non Physically Based Workflow Lights: Standard Lights Daylight: Directional Light and Skylight Exposure Control: Logarithmic − turn on Affect Indirect Only. Units: Make sure your scene is set to the appropriate scale. If you post an image of your scene, it may be easier to diagnose if it's a problem of scale, material, light and/or radiosity settings. Link to comment Share on other sites More sharing options...
Tim Saunders Posted March 6, 2006 Share Posted March 6, 2006 In my experience photometric lights are about all I use with radiosity. Echoing the words in the previous post, show us a test render so we can see the problem. I'm guessing it is the physical scale in your exposure control perameters causing the problem. As a general rule, when using Log. exp. control (which I reccommend), set the physical scale to the same value as the brightest light in your scene. Then you can adjust the brightness & contrast in your exposure control perams. Radiosity can give some killer results, but it will take some testing, a lot of testing to figure out what adjustments effect what. Stick with it. Link to comment Share on other sites More sharing options...
cain Posted March 6, 2006 Author Share Posted March 6, 2006 Thanks for your help guys but I looked over a mental ray tutorial over the week-end and it has worked out quite well for me. I think I will stick with mental ray from now on. Link to comment Share on other sites More sharing options...
jonrempel Posted March 28, 2006 Share Posted March 28, 2006 Hi, Is the tutorial you mentioned something you could share? Jon Link to comment Share on other sites More sharing options...
