kiajoon Posted March 5, 2006 Share Posted March 5, 2006 Hello I am new here and is slogging away at 5 am in the morning on a Saturday trying to get somethign rendered. My office has just acquired Vray licences and I was to start off my first batch render. Everything went smooth at 800 x 600 renders, but I lose all my mapping and textures once I increased the render to 2000 pixels and above. Textures are a mix of standard and Vray ones, namely some wood and stone materials which went blank. Can anyone please help? Thanks in advance! Link to comment Share on other sites More sharing options...
Tim Saunders Posted March 6, 2006 Share Posted March 6, 2006 Did all the materials disapear, or just the material on sertain objects? If it is just on specific objects, it sounds like co-planar faces. That's my only guess. Link to comment Share on other sites More sharing options...
foxlee Posted March 6, 2006 Share Posted March 6, 2006 I have the same problem from time time to time ,probably a bug , just close Max and open again ,the materials should be back. If not restart computer or use smaller size maps. Link to comment Share on other sites More sharing options...
kiajoon Posted March 7, 2006 Author Share Posted March 7, 2006 Well I solved it by changing all materials to standard material..weird. The firat pass was ok, and it seems to lose the materials after. If I render a region everything is fine. Thanks for the replies and any update is welcomed! Link to comment Share on other sites More sharing options...
FlytE Posted March 7, 2006 Share Posted March 7, 2006 are you using vray 1.47 with viz06 ? Link to comment Share on other sites More sharing options...
kiajoon Posted March 10, 2006 Author Share Posted March 10, 2006 are you using vray 1.47 with viz06 ? Yes I am. I guess they are not very sorted out yet as a pair? Link to comment Share on other sites More sharing options...
