enigma Posted March 5, 2006 Share Posted March 5, 2006 What specific setting should be adjusted in vray to remove the prepass for the reflections. I got the idea that it is on the reflection because its still doing the prepass even if i turn off the GI.Its taking up too much time, esp. with rendering animations. Any advise will be much appreciated. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted March 5, 2006 Share Posted March 5, 2006 keep in mind, not doing reflections during prepass will cause problems if the surfaces being reflected are not visible to the camera. in other words, if something is being reflected that is around a corner, it won't have the correct light calculations, and will render funny. at least this is the case with irradiance passes. i am not sure about other methods, maybe lightcache or something would still help them render somewhat accuratly. Link to comment Share on other sites More sharing options...
Da_RoCk Posted March 6, 2006 Share Posted March 6, 2006 I bet that you are using reflection interpolations for your materials. just turn it off and the added prepasses of your IR will be gone or even the IR is off. Link to comment Share on other sites More sharing options...
enigma Posted March 6, 2006 Author Share Posted March 6, 2006 CHG, thanks i'll keep that in mind. Da_rock, let me check on that. Thanks. Link to comment Share on other sites More sharing options...
Da_RoCk Posted March 6, 2006 Share Posted March 6, 2006 an easier way to turn it off if you are uncertain which material has the interpolation is by using the automated script by metin7 can be found here: http://www.metinseven.com/menu_goodies.htm credits go to metinseven of course for a wonderful tool... Link to comment Share on other sites More sharing options...
enigma Posted March 6, 2006 Author Share Posted March 6, 2006 wow very handy kuya mir....thanks a lot! Link to comment Share on other sites More sharing options...
