Kalwall material
d7man2000
  • 2 weeks later...
From what I hear at the Chaos forum, the next release will have a quick SSS material. I'm looking forward to that.
Greg, could you post an image that shows your particular application for the material? Rather than going for actual translucency, there might be a workaround for Vray. But it depends on the situation.
i want to learn to render with vray, if i could use mental ray sss with vray that would work
i found that present sss in vray is not going to work
i found that doubled sided material gave me what I was going for more or less, it gives a translucent effect
Kalwall is tough and the easiest route is SSS...in any application. However a translucent material with proximal effects or maybe fresnel falloff may work too.
Here's an image from the only time I had to do it.
I used C4D and SSS.
