wizuby Posted March 8, 2006 Share Posted March 8, 2006 This seems like a common problem...but I cannot seem to find a decent answer that fixes my problem. I am having random red dots show up in my renderings. The dialog box says, "warning:material returned overbright or invalid color." I had my irradecence map set on preset low, and also tried medium and hi but I still got the dots. Oddly, when I hide everything else in the scene except one of the problem objects it renders fine, but when i turn everything else on again the red dots come back. Some camera angles they show up...others they dont. Any hints on whats going on? Link to comment Share on other sites More sharing options...
Christopher Nichols Posted March 8, 2006 Share Posted March 8, 2006 First off what version of Vray are you using? Next make sure you are not using any 3ds raytraced materials or maps. Link to comment Share on other sites More sharing options...
wizuby Posted March 8, 2006 Author Share Posted March 8, 2006 i am using the latest full version of Vray, and I think all my materials are Vray materials only. I will have to make sure there are no raytraced maps anywhere. Another thing i noticed is that when i turn off my photometric sun and just use the vray sky light...the red dots are gone. Of course the rendering doesn't look as good either. Link to comment Share on other sites More sharing options...
Christopher Nichols Posted March 8, 2006 Share Posted March 8, 2006 Those red dots are usually a sign of unsupported materials, or things like rpc's. I personnally don't like the photometric sun thing... I am not sure about how compatible it is with Vray to be honest. I am more of a vray light and hdri man myself. Link to comment Share on other sites More sharing options...
BrianKitts Posted March 8, 2006 Share Posted March 8, 2006 quick fix is to just go into your raytracing panel and flick off the four check boxes to turn off raytracing. if any materials render improperly then you will know right away which ones to fix. (make use of vray maps, they're a wonderful thing).... Most of the time when I do this I don't even see a difference other than the splotches go away. Link to comment Share on other sites More sharing options...
wizuby Posted March 8, 2006 Author Share Posted March 8, 2006 Im not sure I understand your method. I just turned off the raytracing tabs and rendered again. The red dots were still there...what now? I don't understand your next step. Link to comment Share on other sites More sharing options...
wizuby Posted March 8, 2006 Author Share Posted March 8, 2006 Is there a problem with using bitmaps instead of Vray maps? Link to comment Share on other sites More sharing options...
manta Posted March 8, 2006 Share Posted March 8, 2006 This might sound strange, but ungroup everything, had the same problem once, after I ungrouped, problem went away...give it a try Link to comment Share on other sites More sharing options...
owen072080 Posted March 8, 2006 Share Posted March 8, 2006 I've experience that problem too especially when i use rpc's. Even though i delete the rpc's it still produces red spots. What i do is that i save my mesh together with my cameras and lights as a new file. It works fine for me in the end. I hope this helps a bit. Link to comment Share on other sites More sharing options...
wizuby Posted March 9, 2006 Author Share Posted March 9, 2006 man...i was really hoping that would work, but no luck. I am really going crazy here...i can't seem to find anything that would be causing this. All i know is when i turn off my sun...its fine, but the lighting is crappy. Link to comment Share on other sites More sharing options...
manta Posted March 9, 2006 Share Posted March 9, 2006 Try using a vray light instead... Link to comment Share on other sites More sharing options...
Christopher Nichols Posted March 9, 2006 Share Posted March 9, 2006 Are you sure there is nothing in your scene that has 3d studio raytracing (not vray raytracing)... this could be raytrace material raytrace map architectural material raytrace shadows (as opposed to vray shadows) Link to comment Share on other sites More sharing options...
neba77 Posted March 11, 2006 Share Posted March 11, 2006 There are a few threads on chaosgroup forums that deal with these problems. One of the many things that could produce these kinds of red spots are 90` rotated gradient ramp maps. Sound crazy but i had the exact problem from the mentioned reason. Bye Link to comment Share on other sites More sharing options...
Tim Saunders Posted March 11, 2006 Share Posted March 11, 2006 I forgot where I saw it, but there was something mentioned somewhere about using camera correction with vray occasionally causing this problem. I think it was unchecking "MAX-compatible ShadeContext (work in camera space)" in the VRay: System rollout panel. Link to comment Share on other sites More sharing options...
Ismael Posted March 12, 2006 Share Posted March 12, 2006 One more tip/link: http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=14145&highlight=red+buckets Ismael Link to comment Share on other sites More sharing options...
id_ivan Posted January 25, 2007 Share Posted January 25, 2007 I found out that the way i modelled geometry might also causing the same problem. I mixed the box objects (rectangle with extrude modifier) together with one sided object (the way i used to modelling with radiosity renderer) and the result slap me in my face. I tried to cap my geometry and it didnt work either. I finally re-modelled them then the red dots dissapear. Link to comment Share on other sites More sharing options...
