dnaranjo Posted March 8, 2006 Share Posted March 8, 2006 Hi How can I control the color bleeding of a material when rendering with v-ray? I have a ground plane with a grass texture and it is making my entire scene look green. thank you Daniel Naranjo Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted March 8, 2006 Share Posted March 8, 2006 try turning down the secondary bounce multiplier, like .5 or so. oh, and you can turn down reflect GI in the object's vray properties, it's in 1, you can try .7 good luck Link to comment Share on other sites More sharing options...
manta Posted March 9, 2006 Share Posted March 9, 2006 You can also adjust saturation in the GI section Link to comment Share on other sites More sharing options...
d.sign Posted March 9, 2006 Share Posted March 9, 2006 In the render panel, Vray system, object settings tab (select object first) you can decrease emit GI value to 0.5-0.7... Link to comment Share on other sites More sharing options...
Fernando Lino Posted March 9, 2006 Share Posted March 9, 2006 There is another trick....overwrite your materials with a grey light color...save the light calculation and render it again with materials. Link to comment Share on other sites More sharing options...
dnaranjo Posted March 9, 2006 Author Share Posted March 9, 2006 Hi every one thanx a lot for the tips, now my scene looks much better. when it is ready I will post it so you can see it Daniel Naranjo Link to comment Share on other sites More sharing options...
