skechup model render in Vray
rachelC
:confused: Could someone help me with this problem please?
I was given a model made in skech up. I have apply only 2 materials to check out my lighting. When i render, the image come out grey and grainy!
Could someone tell me if this is actullay possible to render a sheck up model in vray please?
many thanks
Not to hijack, but I just want to know if anyone else is doing thei rmodelling in SketchUp and bringing it in to max for vraying...
If so, what is the best solution for window glass? I think my models have the panes built as a single plane and I have heard from different sources that planes will not reflect the environment.
Does anyone have a good process of this conversion?
thanks,
e
I model in SU all the time and then go with max and vray or maxwell.
Model everything on layer 0 and group your items. Then create your layers that you want the items to be on and then change the layers of the grouped elements to those layers. Export the file as a dwg with faces only and then bring into max.
Works everytime for me and I do it day in and day out.
  • 2 weeks later...
What do you do if you are using someone elses model from SU but aren't sure if it was modeled correctly (tan faces out)? Any other tips for rendering using a SU model? Do you use the same settings in Vray as you would if you modeled it using Max/Viz?
