Can't see my textures in the viewport
bo@albertassociates.com
  • 3 years later...
  • 2 months later...
Hi, I'm having the same problem but I'm using a FR material, is there anyway I can view it in the vieports? The show map in viewport is grayed out. Thanks
You can´t apply the material in the viewport with Final Render Mats, what you need to do is click in the "MAP" you want to see in the viewport (ie Difusse Bitmap/Bumap map) open it then u can click Show Standard Map in Viewport.
  • 4 weeks later...
Hi bow,
Did you manage to find an answer to your problem with viewing your texture?
I have a similar problem - using max 2010, using a .jpg bitmap for my texture, views when I render
but not showing in viewport ( I need it to show because it is a reference plan for my building).
When texture is applied it just turns grey in the viewport ( and it's not the default colour from the material editor).
If I start a new max document the material works fine and can be viewed in the viewport.
I should say that in this max file I have applied materials to other objects and they have worked fine
but this new object is different. I thought that this might be a memory issue but I have checked my settings and
they seem ok.
Any suggestions would be most appreciated. Thankyou.
  • 4 months later...
